lyonsd
- May 24, 2001
According to the instructions that came with my Scamaster 2.1, it is supposed to have the following modes:
When I'm on "iac" and hit the button to go to the next mode, instead of getting "pl" or "sp", I get "cc". And the numbers simply increment. For example, first it will show 04, then 08, then 11, then 17, etc... all the way up into the 200s. Then it will start again with low numbers (but not necessarily the exact same numbers as the previous cycle).
I see that a special prom (series Y or Z) is required for the "pl" and "sp" modes. But what is this "cc" mode?
thanks.
- AF Mass airflow
- L8 Engine load
- bat Battery voltage
- int Integrator
- bL Block learn
- mph Road speed
- clt Coolant temp
- ats Air temp sensor
- r RPM
- tps Throttle position sensor
- iac Idle air control
- pl injector pulse width
- sp spark advance
- mal Malfunction code
thanks.
