scanmaster reading
tntdiablo
i just hooked up my scanmaster and everything seems fine,except the bl(block learn)is at 160 at idle,if i give it gas it drops down.any worries with this #?thanks alot
Should be about 128 at idle. You are lean. What is your fuel pressure? What chip?
Jason
A high blm at idle is usually indicitive of a vacuum leak, or pre turbo exhaust leak (manifolds/crossover).
