Here are the readings.. 1st are not running.. AF 00/ LB 00/ BAT 11.5/ INT 128/ BL 128/ CL 65/ ATS 67/ TPS .42/ IAC 150/CC 00/ NAL -/.............
*** 2ND set are at startup/idle/cold> AF 10/ LB 41-45/ BAT 14/ INT 128/ BL 115/ CL 76/ ATS 69/ TPS .44/ IAC 77/ CC 88/ NAL 00............
***3RD SET ARE UP TO TEMP DRIVING AT 55 MPH>>>> AF 19-21/LB 70-75/ INT 120-126/ BL 117/ CL 164/ ATS 74-75/ TPS ?/ IAC 82/ cc 35-140/ NAL 80-115............
****4TH SET ARE UP TO temp back at home at idle>>>>>>> AF 05-05/ LB 35-37/ INT 126-130/ BL 113/ CL 189/ ATS 103-105/ TPS .44/ IAC 02-05/ c 09-240+/ nal 00........
O2 readings at warm idle 180-750+
87 t-type stock turbo,engine,trans, even chip is factory. injectors factory spec.
Starts up very rich + runs/idles a little rich, no cat, turns over 8-10 times before it catches, and smells up car with raw/unburned fuel smell. any ideas from the readings? I just bought the car and this is how it was set up. Runs about 10-12 psi on turbo.
Thanks, James......... ie.. noob!!!
