hello peoples; I just installed my SC and I'd like someone tell me what are the preferred numbers I should be looking for?
I don't mean bat voltage,vehicle speed,coolant temp.,RPM,TPS. I mean airflow reading,LV8engine load,Integrator,Block learn,cross counts then the insructions show that the SC should show Injector Pulsewidth and Spark advance that I don't see. I also forget what number the IAC should show could someone remind me of that.
Basically start from the top of the display codes and go down. One thing the SM did show was my AtS was blinking hot and that probably is because I don't have the sencor in the air stream. I just tie wrapped it on the OD of the CAI.
thanks for any help
IBBY
thanks for any help
IBBY
