Mar 29, 2003 #1 G GNDen Member Joined Mar 18, 2003 Messages 97 At idle my BL(block learn) and INT (integrator) are at "160' and decrease as I drive. Is this normal??? What should this settings be at idle? Thanks!!
Mar 29, 2003 #2 T TurboDave RIP DAVE Staff member TurboBuick.Com Supporter! Joined May 24, 2001 Messages 14,013 No that's not normal. High BLM's at idle are indicitive of an existing problem/s. It could be one or more of several things, the most common of which would be a vacuum leak/s A pre turbo exhaust leak/s Or much less common, a badly programmed chip.
