squeeze87 had tuning issues similar to this, but I didn't want to interrupt his post, and this is a little different. I've been trying to tune the GN today since I've just installed my Scanmaster 2. I have that "archaic" Pit Bull chip (like BLACKBADGER) that was originally installed in the car by the original owner in 1988. In other words, I have no idea about it's programming.
The first blast I made today, Boost was at 12psi, FP was 43psi, O2's at 765-780, with 0* KR. The coolant temp has stayed at a consistent 175* all day long. I thought it could go higher than 12psi, so I upped the boost in 1psi increments until I got to 15psi, where it developed 8*KR. I adjusted the FP in 1psi increments until I got to 48psi and the KR went away but the O2's shot up to 835. That seemed kind of high so I lowered it to 46psi. I'm running Sunoco 94 (with MTBE) in it and I am still getting 4*-5* of KR with the O2's running about 805-815. It seems to knock around 4200rpm in 2nd gear. It's not a "rattling" knock, It's more like it knocks once (audibly), like 2 pieces of flat metal being slapped together and that's it. OUCH.
It did this exact same thing a while back with the stock WG before I installed the Walbro 340, Accufab FPR and Hotwire kit. As soon as I installed those, the knock went away. It just wasn't getting enough fuel. But I am hesitant to go too high on the FP because I don't know too much about the flow charachteristics of these injectors (Red Tops) at higher pressures (the point where they develop an erratic spray pattern). I was wondering if you guys thought 48psi FP and 835 O2's were too high?
BLACKBADGER mentioned in another post that the Pitbull chip has rather high timing. Is it so much that it can't handle 15 psi boost with 94 octane fuel? It does have rather crisp throttle response.
On top of that, it has stored a Code 13 (O2 Sensor). Since the O2's had gone up to 835 at one point, is that more than the O2 could hande and it's fouled now? The O2's are still fluctuating as they should during normal driving, around 425-460, which leads me to believe it's still funcioning properly. I haven't added any additives or race gas to the tank, it's straight 94. It's the original O2 Sensor so I was planning on replacing it anyway....and now I'm thinking about a new chip for these injectors. Either that or I may start blending race gas with the 94 like BLACKBADGER does, but only if absolutely necessary.
Sorry that was so long, but this tuning game is new to me. I'm used to wrenching on V8 Camaros; I never knew these TR's were so finicky.
I'd like to get up to 18psi boost but I'm certainly not going any higher yet.
Thanks in advance
Thanks in advance
