nothingman
- Mar 24, 2012
So I've been becoming increasingly frustrated with this carb that I rebuilt... The choke hasn't been opening completely and then after running for a good 30mins it will shut sometimes killing the car. I've already swapped another electronic choke coil in and same result so I'm thinking there is an electronic issue in the wiring. So I have temporarily propped the choke open and that solved it, which has me thinking about removing the choke all together. Not to mention I've read in both of my rochester service manuals that folks remove it sometimes.
Well anyway that isn't my main concern but I'm not sure if it has anything to do with the secondary air valve malfunction. My main concern is the secondary air valve butterflies do not seem to be opening??? BTW I've got the the secondary butterfly stop lever held back so they are free to open. What happens is when i'm accelerating I hear the turbo start to spool and the boost gauge approaches 0 then as it heads to 5 psi when i feel like i should have some pickup... I get nothing but a cloud of unburnt fuel puffing out the tail-pipe and a motor that feels and sounds like it wants to get up and go but is being restricted??? I've swapped the front vacuum break for one that held vacuum but still same issue. i'm convinced the air valve is not opening but since i can't see under the hood when i'm driving i'm not 100% sure. Has anyone experienced the same issue or know how to test for my problem? Should the air valve open when i rev the car in park, because it isn't? Any help would be much appreciated because it has seriously been driving me nuts haha. thanks!
