deezdad
Jackie's cashing in on your wretched disfigurement
- Mar 25, 2005
Looking to do a little screwing around with my 87-T on the road this spring...pick and accept races from the mustangs and rice and other performance cars on the road, but have some questions... When lined up at a light what do you do to pre-pare to launch? do you let it idle and just hammer it at green or do you hold the brakes and build boost, if so how much? i do have a boost guage and a scanmaster. when do you start building? my car has the aftermarket gnx suspension that kirban and his buddy did, with firehawk tires on 16" rims. do you go full throttle or do you base it on scanmaster knock retard? at what knock retard should you back off if any? i use 93 octane. I live in northern rhode island and lately have been cruising around burning gas looking for action but none! any particular way to let people know your looking for action or does it just happen? at highway speeds it seems when i give it throttle it shows knock instantly, is this normal? very irritating to have to back off because i don't want to blow the engine. car has the rjc power plate, duttweiller i.c. neck and stock air box with k&n stock replacement filter in it with a ram air snorkell built into the air dam leading to the air box. has the 13" baer brake set-up on the fronts so i can stop safely too. any tips on how to road race and not kill the car would be greatly appreciated...thanks
