I measured the center section endplay, as described in the CK manual, and I think I may need a selective thrust washer that is thicker then a #15 from the list below.  Would this much endplay imply that a part needs to be replaced?  If so, what part?  The thrust washer between the center support and direct drum looks ok.  I've heard I could put a shim behind it, or use 2?
I can make my own selective washer; would Delrin work? Is there any real thrust load placed on this washer?
Thanks.
Thanks.
