I have decided to sale my hotair exhaust pieces. It's a KB set that is currently painted with eastwoods black manifold paint. Has all band clamps, but would need a set of header bolts for passenger side header ( I'm reusing the bolts for current manifold). The up pipe has been drilled for an egt probe so it will either need to be welded or you can use an egt gauge. The dp started as a Mease stainless 3", but for the kb headers it had to be modified to fit. It is a 2 piece pipe with the 3" band clamps which are included. I was using a slip fit dump pipe ( custom ) so you may have to fabricate a pipe the correct length for this pipe. When I bought the pipe from mease I paid for a dump pipe as well, but it didn't come with one. I figure myself lucky to get the downpipe at least.
Was thinking $350 for kb exhaust and $350 for dp. Or $650 for both. I would suggest that the person that buys the exhaust headers also get the dp since the dp is purpose made for them.
