tonylukejr
- Aug 31, 2002
I am selling a FAST 87 Grand National with t-tops. It has 2100 miles on a completely rebuilt and balanced motor and trans. The car itself has 100,000 miles on it but a lot of mechanical work has been done to the car. It has power locks, windows and seat. The car went 12.3 in the 1/4 mile and that was before I added the propane injection. The 12.3 was at 18lb of boost. but with the propane I am running 22lb of boost with NO KNOCK. Car currently has WELD Racing rims but I have the original GN rims as well. I also have a set of slicks that came with the car when I bought it. Interior is in good shape but headliner is sagging and door panels need attention from T-Tops leaking. T-tops are fine but the seal needs to be replaced. Seats are in great condition. Deck Lid has some rust along bottom edge and doors have minor rust along inside weld and paint is in fair condition. Listed below is what has been done to it. I am asking $ 8,500.00 or Best reasonable offer. Email me at tonylukejr@hotmail.com with any questions. The car is located in Southern New Jersey
NEW PTE FRONT MOUNT INTERCOOLER
HOT WIRE KIT
ADJUSTIBLE FUEL PRESSURE REGULATOR
NEW KNOCK AND CRANK SENSOR
DOUBLE ROLLER TIMING CHAIN SET HIGH VOLUME OIL PUMP
42 LB INJECTORS
TE44 TURBO with adjustable WASTEGATE
WALBRO 340 FUEL PUMP
3 INCH DOWN PIPE
HIGH FLOW CAT CONVERTER
NEW 3-INCH EXHAUST SYSTEM FRONT TO BACK WITH DUMP
NEW FLOW MASTER TWO CHAMBER MUFFLERS
TRANSMISSION done by ART CARR trans has all EXTREME DUTY PARTS and can handle 850 hp.
9 INCH CONVERTER-3600 STALL.
ULTRA THUMBWHEEL CHIP.
HYPERTECH 160-DEGREE STAT.
Jay Carter Propane Injection
COMPLETELY UPGRADED SOUND SYSTEM
NEW COMPUSTAR ALARM SYSTEM WITH REMOTE
HOT WIRE KIT
42 LB INJECTORS
3 INCH DOWN PIPE
