Any thoughts on how to accomplish a 3800 series II into a 1972 Nova? I was going to swap in an LT1 from a late model Camaro. This can be done quite easily. I have done my research and have found all the resources necessary to make this happen.
I love my 97 Bonneville with its 3800 so it got me thinking. I thought it would be cool to have an L67 supercharged 6 in my classic. After researching this I found it can be done but with extensive mods. The FWD 3800 accesory/pulley locations interfere with the frame and the supercharger intake extends so far back that you have to cut a hole in the firewall.
I thought maybe a rwd v6 out of a camaro/firebird would do the trick. If the LT1 swap is so straight forward why not the 3800?
I found the resources to swap an L67 supercharger to the L36, but I can't find anything on the engine swap itself.
My intention the plan is to start small. This car has a 100hp straight 6. I could spend 1000 to 1500 to add a bunch of power goodies and we only get to a little over 200 hp. That's twice the power so the car should move pretty good. You can get a lot more hp, up to 600, out of the straight six but it become much more difficult after this point.
With the 3800 I already have the 200 hp. Add the eaton and i'm up to 250. As you know this is stock hp and simple odds improve on this immensly.
All I want to do is get it up and running and then eventually break it down and make it really move out. I want to be able to cruise in this thing and have some fun while I restore the rest of it.
There's this guy out there that did a great job putting an l67 into an older rwd cutlass, but the mods he had to make were extensive. So, I feel that starting with the l36 rwd set up from an f body is a good route for me as you can already easily swap the lt1 from these cars.
