last week we did some testing with the servo cushion spring in the servo.Most of the tech will be in the manual supplement which has now been put off so I can add some more stuff,im such a procrastinator right?Never leave this out i performed back to back to back tests with it in and out with stock and my servo as well as clearance adjustments larger than mt specs in the manual.bottom line ,the cushion spring removed IS THE REAL CAUSE OF A 2/1 DOWNSHIFT/OR MINIMUM OR CLOSED COASTDOWN CLUNK WITH A FUNCTIONING 1/2 ACCUMULATOR .THE SHIFT QUALITY WITH IT REINSTALLED WAS LESS BANGY WITH 0 SLIP AND THE CLUNK DISAPPEARED .Ill give full details on each change and the results yeilded when i get around to it.very interesting stuff.
