1985 Buick Regal Grand National $10000 OBO
With 1987 Engine, Transmission, and 8.5" rear end. Odometer reads 69,000 and counting. Engine has aprox. 30,000 miles. Cylinder heads and head gaskets and all other gaskets have about 1500 miles.
Engine Specs:
- Brand new cylinder heads with metal shim head gaskets, ARP head studs, Engine bored .030" over with TRW pistons and I-Beam rods and stock forged cams.
- RJC racing plenum separating plate.
- Turbo specs are .63 compressor housing, .60 exhaust housing, turbine wheel is 59mm, NO SHAFT PLAY also NO SMOKING FROM TURBO.
- Newer GoodYear gator back belt.
Transmission Spec:
- Stock 200R4 transmission
- New transmission filter, gasket and fluid.
- 2800 Stall converter.
Rear end Specs:
- Stock gears.
- New pinion seal.
- New Brute Force universal joints.
Brakes Specs:
- GM front pads at 50%.
- GM rear shoes 75%
- New front brake lines.
Fuel Sys:
- 42.5 lbs. injectors.
- Brand new walbro 255 LPH fuel pump.
- New fuel filter.
Steering Specs:
- New steering gearbox.
Wheels/ Tires:
- Center line convo pro wheels.
- New Hankook tire in the front
- New Nitto Drag Radial in the rear.
Electronics:
- SMC alcohol kit.
- Scan Master 2.0
- Pre wired AEM wide band
- Electronic fuel pressure gauge.
- Mechanical oil pressure gauge.
- Electronic volt gauge.
- Electronic water temperature gauge.
- 30PSI Boost gauge
Interior:
- Interior is in excellent shape for being over 20 years old. The seats have not rips or stains.
- Needs new wiper stalk.
- New driver door window motor and switch.
Exterior:
- Paint is good shape for the age
- Small rust spots on C-Pillar, Above driver door.
- Trunk paint is slightly fading.
- Outer window wipes are brand new.
Other:
- Viper Alarm with ignition kill switch.
- Car running in excellent shape it is my daily driver I'm a GM mechanic so I know everything about this car.
Please feel free to call me for any other questions or if you want to come by and check it out. MORE PICS UPON REQUEST
-----------------------CAR IS LOCATED IN BOCA RATON FLORIDA---------------------
Please give me a call at
914-837-2766 -Christian
914-882-6923 -Dominic
Engine Specs:
Transmission Spec:
Rear end Specs:
- Stock gears.
- New pinion seal.
Brakes Specs:
- GM rear shoes 75%
Fuel Sys:
- New fuel filter.
Steering Specs:
Wheels/ Tires:
Electronics:
- SMC alcohol kit.
- Scan Master 2.0
- 30PSI Boost gauge
Interior:
Exterior:
Other:
