SignUp Now!Originally posted by jamesmac
Don't want to step on any toes here, but I have torqued a girdle onto a regular 109 block, & seen the block distort as it is tightened between the block & the girdle.
I should mention that at the time I had a standard bore 109 block, & a standard bore SGI block & was asking the same thing myself.
So I torqued the girdle on the SGI block & there was a big differnce in the distortion of the block.(SGI better)
GM put more meat around the bottom of the cylinders in the SGI block.
Originally posted by cool 84
As far as I know the stage I is more closely related to a stageII block than a stocker. Way more material in the main webbing, can be drilled for 4 bolt mains, cam moved higher in the block to clear stroker cranks, and all around beefier. Looking in the Buick Powersource book, it also weighs a bit more than a 109 block. It's been a long time since I've seen one but I think it has the material there for the extra head bolts too. I've heard it's basically a stageII block minus the extra machine work.
Originally posted by Wht87T
Well that definitely clears up some questions about my block. Thanks for the replies!
Originally posted by 86brick
So I take it that means you got a SG1 109 block? I'm looking forward to seeing your car at the Bradenton event! Maybe you can beat out Louie for having the fastest Hartline built stock block (TSM) car
Originally posted by Louie L.
Dont count on it
Originally posted by Larry
Ahhh- yeah , but- I always thought the shortest distance between two points was a STRAIGHT line? Did you see the photo of his car- is that the Space shuttle in disquise? Larry
I feel the love from my fellow new jerseyans......
