turbokinetic
- Jan 29, 2008
Hey folks. I had to partially tear down my engine to change some gaskets.
These pictures are of the engine as it was when opened up. Nothing has been sprayed, wiped, or in any way cleaned.
I have exclusively used Shell Rotella T 15W40 oil in this engine, from the first fill to present. The change interval has been 4000 miles, with a few 5000+ mile "oops" late changes.
This makes me very happy to see. There is not any sludge in the engine. There is just BARELY some varnish on the bottom of the intake, below the EGR passage.
The rocker pivots, pushrod ends and cam lobes (roller) all appear perfect. Cylinder walls still have good cross-hatch. The Turbonetics GTK450 ball bearing turbocharger still feels like new as far as shaft play goes.
This is a daily driver, running 15+ PSI boost when called upon. It has open-loop only speed-density tune with lean-burn highway mode enabled. The engine is LG3 variant of the Buick 3.8SFI V6. This is the 'front wheel drive' 86 - 87 spec engine with factory roller cam. I believe the 89 Turbo TransAm engine is closely related to this model, for what it's worth.
I will continue using this oil. Just wanted to share my experience.
Sincerely,
David
This is the only area with noticeable varnish:
The intake valves. No noticeable deposits. This engine has never had any sort of injector cleaner or top-end cleaner used in it. It has had mostly Shell / Chevron / BP 93 octane gasoline, whenever I can get those.
Sincerely,
David
