shifter cable help
87GNattyKid
Hey guys, i just brought my 87 turbo t to pep boys for an inspection and they somehow managed to break the shifter cable out of the rubber boot. Its clamped back on now as a temporary fix but i was wondering where i can find the correct cable for the my car? i looked around and saw a few people saying that sometimes parts stores were ordering them one that was too short? I found this one online, is it correct? And how complicated is it to install? Thanks
http://www.rockauto.com/catalog/raframecatalog.php
also, after they clamped the shifter cable back together, my reverse lights dont go on, could that be because the cable isnt set properly?
Have them buy it from G-body parts or nos4gn (both are vendors)
Save yourself A BUNCH OF HEADACHES & buy the OEM part ONLY
do a search, I went through 5 aftermarket ones.
OEM is more $$ initially, but CHEAP insurance in the long run...
Install is straight forward; cotter pin & washer on each end;
make sure you don't swap your ends
you don't even really need to jack the car up; takes just a few minutes
No idea about the B/U lites :confused:
Do_O
