Shop clean out - Misc extra parts
captrob
Slow GN Fizz!
* All used parts from ‘86/’87 Turbo Regals
* All are plus shipping
* Pick-up or shipped from Keller, TX. 76248
* Paypal F&F or add 3% please.
* Ship only to CON-US of course. Anywhere else extra *
- Stock throttle body-Bored 62mm by Jay Jackson years ago. No coolant hose nipples. No IAC, TPS, or cable arm. Includes gasket and studs/nuts. … $50
- Stock crank pulley…..$20
- Stock fuel rail…$20
- Stock upper plenum(dog house)…….$20
- Stock turbo inlet bell with rubber cap…$5
- Aluminum vacuum blocks (2) – 1 stock style with finned top, 1 with vacuum brake tap. Flat top …$10 each - with gasket and hardware.
- Stock air filter canister top …..$5
- Stock air filter canister top 90* elbow……$5
- Stock intake fresh air snorkel…….$5
*Take all 3 for $12
- Trans dip stick and tube …$30
- Passenger side valve cover - Was polished at one time. With grommet. Bought off this board several years ago. I only needed the driver side….$25
- Stainless Steel valve cover bolts/washers…$10
*Take both for $30
- Fuel tank hard lines – 3 lines from tank over the rear end……..$15 (pretty long so box will be fairly big)
- 86/87 intercooler brackets – 1 driver side, 2 passenger side…….$10 each
- HR poly engine mount(Driver side)…$50
- Rt. & Lt. lower door panels w/concert sound. Panels in good shape. Arm rests are not great…Dark Blue……$75 (Would like local pickup. Pretty big box)
- Driver side header- I believe is from Postons years ago. Barely used. Upgraded to Hedman Headers. No leaks. Good ball flange ……$50.
- Stock “X” braces in front of radiator…$5
- Stock idler pulley – needs new bearing…$free (just pay shipping)
More picture soon.
Thanks, Rob
captrob@hotmail.com
I’ll take the stock Intake parts all three, also the fuel rail and HR driver side mount.
Interested in drivers side header. Can u post a pic? Shipping to 32097? I would also like HR driver side mount.
I'll take intercooler bracket. pass side. And the idler pulley too.
Pm your address. It's been a while, but I bought parts from you before.
If this stuff is still for sale i will take the following.
Fuel rail
Upper plenum
Inlet bell
Vac blocks
Air box parts
Intercooler brackets
Polly motor mount
Please let me know and i will paypal you or whatever works for you.
Here is header and HR engine mount pictures. I'll get it weighed up Scott and see what it comes to...
Thanks, Rob
Here is the HR mount and fuel rail (no cap) pics
Here is the order that I received posts pending shipping and their confirmation :
TRICKSIXPA - 3 Intake parts, HR mount, Fuel rail
SCOTTHEIDINGER - Driver side header
TURBOTERROR - 2 Vacuum blocks
JBAKER - Rt/Lt intercooler brackets
