Shorted out my car
Sweet6
I shorted my car out while disconnecting the battery. It sparked pretty bad. Now there is no power to the car. Any ideas what I blew?
TIA
Did you disconnect the positive terminal? If you do the negative to disconnect power (or negative first when pulling both terminals) you dont have to worry about your wrench shorting out on anything but the positive terminal.
Originally posted by bkoons
Did you disconnect the positive terminal? If you do the negative to disconnect power (or negative first when pulling both terminals) you don't have to worry about your wrench shorting out on anything but the positive terminal.
Oh, do you mean the heat shield blanket over the coolant reservoir?
