Should the Converter be ok
BOP4ever
I am looking at a converter from a guy and have a question. He had it in his car and on a pass at the drag strip it sounds like it flaired on a shift and I guess slipped the band or clutches so afterward due to also loosing a rod bearing he upgraded to a 3 speed trans and added more power... Should I pass on the converter for fear of something hurting my trans becuase of the slip during its last run behind his engine or is this anything to be concerned about ?
Look to see what's in the bottom of the Tran's Pan if possible. Any metal & TC would need to be cut open and cleaned. May just need a flush & go.
