NY Twin Turbo
All the good stuff.....Times 2.
- Dec 10, 2014
So can someone clearly define a Siamese block for us? I googled it and am still confused because the photos used to illustrate the difference look to me to be the same thing sometimes.
In the photos on gnttype.org, the Siamese blocks appear to have two coolant passages along side each other above and between each cylinder. Is this Siamese?
When I Googled the info, the definition of Siamese is cylinder bores without coolant passages between them. Is this Siamese?
When I look at the photos above, I see coolant passages along side each other (round and square) with steam holes between each bore. Is this Siamese?
Can someone clearly define what a Siamese or not Siamese stage block look like. Also, are the steam holes desirable or are non desirable for a serious performance build engine?
