Siemens 3105 Deka 83# (870cc) Low-Impedance Injector
rollie
TurboBuick.Com Supporter!
250 dollars shipped
Genuine Siemens DEKA I Low Impedance Injectors
These injectors flow 86 lbs/hr at 43.5 PSI ( 3 BAR )
FEATURES:
Genuine, reliable Siemens Injectors
Excellent response characteristics
Robust Design
Low Impedance
Specifications:
Coil Resistance: 2.35 Ohms / Low Impedance / Low-Z (Peak/Hold driver circuit required)
Static Flow Rate @ 43.5PSI ( 300kPa ) w/Gas: 86.2 lb/hr = 888 cc/min = 652.2 g/min
Connector: Bosch EV1
Spray Pattern: Pencil
Factory fitted with Viton upper and lower o-rings
no clue they work great track use only with c-16 I had to jump up to 96lb
