Last weekend at the Midwest challenge, the car was popping really bad only at upper RPM under load. Coil pack checked good, new plugs and recent wires. Plenty of fuel pressure and volume. Car just about cuts out. It seems like a lean pop to me (intake).
Plugs are quite white, tried 103 & 104's - no help. Approximately 10% of fuel is always being pulled out (just like it did when it was first tuned). O2 is around 10-9.5 : 1 and NO black smoke. Starting to see pieces of head gasket in recovery tank and pushing out some coolant. NO KNOCK at all. Problem is, the car has always been a smoker (oil). Can the O2 go out after about 75-100 miles of this smoke? Most of the mileage is track type (to from lanes, passes etc.)
Is there anyway to check the sensor? Anywhere to send it to check it? Are these things really ~$350?
