Big car show tomorrow and trans decides to act up. Seems to be slipping and shuddering when starting from a stop, BUT not all the time. I noticed when I put it in drive, it didn't feel to 'positively engage'. Usually it will start rolling from idle, but now engine rev's and it barely moves like it's slipping, then if I give it more gas it feels like it fights back and shudders. Once it gets to 2nd it drives fine. Doesn't matter what position the shifter is in, behaves the same. Coming to a stop, it down-shifts from 3rd to 2nd, then to 1st. Fluid is full and looks great, may have a slight burnt smell (trying to pretend nothing is wrong...). Trans has been working great all summer, after putting in CK shift kit and billet front drum end of last summer. Trans already had performance clutches and servo. Firm shifts (chirps going to 2nd) and great response with CZ valvebody and governor front Monte SS. Pro Torque Non-lock up 2800 stall converter behind a Pontiac 400. I have not taken pressure readings yet. I checked pressures after the shift kit was in, and everything was fine.
Any ideas would be greatly appreciated. Thanks.
