Shifter(stock) works fine...but when in gear the shifter is sloppy...I can move it back and forth around an 1/8 inch...is the cable just stretched and I need a new cable or is there some type of adjustment that can be done?...
On mine, the pin that the cable slips over is worn and has a groove cut into from the cable. I used a small washer to space the cable out a little and it works fine now..
