Everybody always says to post up SM #'s for opinions. I never have, so here goes. All readings taken at idle. Only KR recorded since new chip 6-8 mos ago was during tweaking, and maybe a 1.9-2.1 during a 3-2 downshift.
O2 - 746 & falling slowly
AF - 04-05
L8 - 28-32
Bat - 13.6 - 13.9
Int - 128
BLM - 136
MPH - 00
CLT - 175
ATS - 95
RPM - 800-850
TPS - .42
IAC - 24
CC - all over the place, climbing anywhere from 2 counts to 9 counts at idle
Question #1 on a CAI requires a little background. PO installed one of the old ATR ram air intakes. It scoops air from under the car (same place as the IC scoop), turns 90* to driver side, turns 90* up & goes behind headlight, turns 90* to go underhood, into factory airbox, 90* up again, 90* back to level, then into the MAF, then a couple of slight bends into the turbo. Long roller coaster ride for air. I'm considering a TinMan CAI, but haven't pulled the trigger. When I bought the car, the PO gave me a bigger K&N filter & told me it would fit in the factory airbox (which it does NOT). So I got this bright idea to improvise by removing the factory filter housing, stick the new bigger filter there with no housing on it, and attach it to the single 90* where the ATS is, then back to the factory MAF. Took it for a test drive and it sounded WAY COOL, but at WOT, power fell off terribly. I checked AF on the SM and it was only going to 180. TPS would go to 4.60, so I know the mat wasn't in the way. I WOT'd a few more times and my O2's would really reall weird like 011, 120 - really low, but I never got any KR. Is this a simple case of TOO MUCH airflow for my combo? I am thoroughly confused by this, so if anyone can explain I am here to learn! BTW, I did put it all back the way it was and everything is back to normal.
Question #2 on oil additives. I needed an oil change before running at the track tomorrow (still running factory flat tappet cam). Nobody around here sells ZDDPlus (i will be buying a case from one of our vendors now), but in the process of checking all the parts stores within a 5 mile radius at lunch today I found a Lucas product with Zinc in it that is for engine break-in. It's called Engine Break-in Oil Additive with TB-Zinc Plus. Came in a 16 oz bottle that says to leave in for 1000 miles, then change oil. It's made for new rebuilds. You guys think this is OK to run until the ZDDPlus gets here? OK to run at the track tomorrow? I'm not really interested in wiping a lobe, but it would speed my purchase of a roller setup, rockers, timing chain, cover, etc. etc. Thanks for any and all comments!!
AF - 04-05
L8 - 28-32
Bat - 13.6 - 13.9
Int - 128
BLM - 136
MPH - 00
CLT - 175
ATS - 95
RPM - 800-850
TPS - .42
IAC - 24
