Small odd things
jdpolzin
Need a few small odd things for a little project I'm working on. Don't laugh, just need these parts!
1. chrome cap that pops onto the top of Walboro fuel pumps, these often get lodged in the fuel hose when you pull the pump out. I need two of these.
2. Fuel socks, tried finding them at the parts store, no luck. Two for standard walboros. I don't care if these are used as long as they are clean enough to use. Tired of looking at the parts store.
3. Grommit for the passenger side valve cover
4. stock oil pump gears (removing my high volume set up)
5. Bracket for the throttle cable on plenum
Thanks guys! ----Jeremy
Jeremy, I think I have a set of stock oil pump gears if your still in need. LMK.
Tom
Hate to tell you, but if your oil pressure is too high, your bearing clearances are likely to be too tight. Have you thought about putting in a lighter regulator spring?
Motor hasn't made it off the engine stand yet. Planned on high volume gears, going with stock instead. But I pitched the stock gears.
I did find the stock gears btw. Thanks though Tom!
