Wilkinshc
I'd actually like to have a 75lb shot on the bottom end. I'll let Streetking give you specifics,he should be back today. Good numbers though! Duttwieler was actually impressed with the little motor, said he ain't seen that kind of oil pressure(60-70) thru all rpm ranges. Well over 400hp. with marginal boost pressure. I guess he mostely uses Turbonetics Turbos ,but was impressed how aggressive the Pte 53 was. So who knows what it'll produce once the boost is at race levels
I know the Pit-bull is out dated but I sure like the throttle response and spool=up. Going to send Lubrant back a Street chip, (91-92 oct. 18*timing,16-17# boos,36lber'st) Man the chip had the worst tip in stumble ,slow spool-up,and . See if he can't burn something very much like the Pit-Bull but a little more up to date, and pull some timing out at WOT. It(street chip) ran good in Streetkings ,my car hated it,my car seems to really like the Pit-bull, no stumble ,immediate throttle response, good numbers. And the ETOH keeps the KR away
The car is running about as aggressive as I can get her with the combos and minimal knowledge/scan tools I have(but I'm learning). I'm sure a Wilkins Thumbwheel chip would get the most out of her, especially some type of variable timing, high(30-32) on the bottom then step it down thru the rpms , and have wot timing at(22-24). The SMC system is a nice unit , it's nice to run with no KR. You should consider it ,I know your hooked on the laughing gas though.
