Striker,
Yes, the new ones have a gauge, but the problem is you need someone else to hit the button in the car while you read it. It also will not spray until pressure is at least 40psi.
JeffW,
You battery voltage should be around 14, but its not uncommon to get those readings at idle. Checking the grounds carefully would be a good idea.
James
