so far i have drilled the holes in the up pipe which are 25/64" holes...the nozzle fit ok but i accidently tightened one of them too hard and it bent the end of one of the nozzles off so now it's just open in the back of the nozzle with it looks like part of a spring showing...can i still use this nozzle or is it bad and do i need a new one...i figure it looks like it will still flow alky through it...
another thing i am having problems with it the brass fittings on each side seem way too loose against the up pipe...what i mean is that the rubber washers that are inside the up pipe with the head of the nozzle and the brass fittings that go against the outside of the pipe seem too loose and too much play...i can't get it to where it's tight because the rubber washer will just slip over the head of the nozzle when i tighten...will i be ok if it's a little loose? it don't look like it's gonna leak but it might...so far i am pretty disappointed with the install part of this system...maybe i am just stupid or anxious but it shouldn't be this hard should it???
