trbochv6
On the dual nozzle set, i'm using the size that came with the kits and i forgot or did not write down the size jets.
After a few days of tuning , i keep the motor speed at 9-9.5 and have the alk start about 6-7 of boost. It is alittle low, but found that it works best with 6-7 lbs instead of the 10 lds of boost, I'm running a total of 19 lbs of boost.
hope this will help you out, i have future plans with the chip up grade, will play with the set up.
