SMC kit and RJC powerplate
Murt TTA
Condoms prevent minivans
Has anybody had any problems with this combo? I already have a power plate installed but some time over the winter I am going to install my SMC single nozzle kit... Are these 2 compatable??
Thanks,
Murt TTA
They are on both my cars with no problems.
The alky. kit is the wiser choice in MHO. :)
They go together like bread and butter. The powerplate distributes the mix better so you can run more timing without detonation.
Another user here of that particular combo mentioned. No problems here. Single nozzle with pump speed max at 9.5 (shouldn't that have registered 11 like with Marshall Amps?), spray on at 12 PSI. Oh yeah... drilled the hole too!:D
Mark,
I just read the saying on your signature. Your a very sick man!!!
I have the dual nozzle set from SMC and the RJC power plate. Both item work together just find. The SMC system does work very well so far. Smc has a good product and it does what it claims.
Dedmomcat,
With your dual nozzle kit, what size nozzles do you have and what settings do you have yours at?
THanks
trbochv6
On the dual nozzle set, i'm using the size that came with the kits and i forgot or did not write down the size jets.
After a few days of tuning , i keep the motor speed at 9-9.5 and have the alk start about 6-7 of boost. It is alittle low, but found that it works best with 6-7 lbs instead of the 10 lds of boost, I'm running a total of 19 lbs of boost.
hope this will help you out, i have future plans with the chip up grade, will play with the set up.
