SMC problem?
frank700
Hi guys, I took my car out Saturday night. It started running like crap before I got home. Ok now what is wrong! Go to start it and I hear a noise under the hood. The alky pump is running. As soon as I turn the key on. The orange light is also on that tells you it's spraying. Checked the ground and power wires. I unplugged the pump under the hood until I can figure this out? I tapped the box thinking the boost sensor in the box was stuck.
Now I hear SMC is out of business.
Any help would be great!
Thanks!
Older non progressive, or progressive with small controller ?
Mine is the old, big controller.... got a new boost switch from coolingmist.com
Check for conductivity across the two contacts with it off, if so its the switch.
