750H.P.V6
Brutal 6 Racing
- Sep 4, 2001
Hi Terry,
Sorry to hear you're having problems. I have to agree with some of what's been stated above. If you're using 3 quarts of oil in 1500 miles and the oil turns black almost overnight you've got problems. This is an indication of a ring seal problem.
Another issue with all the Champion GN 1 heads is the crappy exhaust guides they come with. The problem with the first version heads was that the guides couldn't handle the heat of the exhaust gasses and fell apart. Champion went to steel guides with K- line liners shortly there after. These guides suck.
Basically a K-line type insert isn't designed for long term use and is not correct for the application. If you have a set of Champion GN1's with over 1500 miles on them the exhaust guides will already be well worn and the car will smoke at an idle and under decelleration. We change out all the guides prior to installing the heads. As usual Tom at Champion will deny there is a problem.
Back to the original post, I think you have a ring problem. I'd say you should do a leak down and see what you find.
Good luck.
Neal
Good luck.
Neal
