This is a long one! My car smokes mainly on startup (blue). I suspect the turbo seals. There is oil inside the throttle body and intake. I also saw oil in the turbo compressor housing. But, there is no oil in the intercooler or outlet pipe to t/b. The oil is bad enough that all the vacuum hoses swelled up. The wastegate hose blew off, overboosted, and blew the headgaskets!
I'm not totally convinced it's the turbo seals. This did all start after complete rebuild #2 (comp cam wiped a lobe and put metal filings thoughout the motor.) I flushed the turbo at that time, but did not send it out. I've had the cylinders honed and re-ringed twice and had the heads done twice, valve seals 4 times, and intake gaskets 3 times. Has anyone had turbo seals fail and show these symtoms? I was dissappointed to get no oil from the intercooler after hanging it upside down for 2 days now. Any suggestions before I toss a set of headgaskets in it and replace the turbo. The motor is out ofthe car. I can't afford to waste any more money on this problem. All of these rebuilds have been done in the last 2800 miles. Dave C.
