- May 24, 2004
New motor still smoking but here is the wierd thing, you can crank it up cold NO smoke, going down the road NO smoke if you let it idle for about 10 seconds especially hot it will start smoking. When it does this you can pull the motor up to about 2500 rpm and the smoke is gone but let it idle and it comes back. I had a friend of mine tell me he had one do this one time and it drove him crazy till he found the intake gasket was the problem. At idle it pulled a hard vacume and it was sucking oil into a port but when you reved it up and held it the vacume in the intake was a lot lower and wouldn't pull the oil in. I am going to let it idle this weekend and get to smoking good then shut it off and pull the plugs to see if I can pinpoint which one it is going into but I wanted to see if you guys had any other ideas on it. I pulled the uppipe off and its dry as a bone so its not my turbo seals doing it. I also popped off a breather and made sure I didn't have oil filling up the valve cover and all was good there also. Thanks Daniel Ray
