Last night was tightning the valve cover bolts down (really loose for some reason) anyway i was turning the one on the bottom side of the drivers side, and it just keeps turning. I cant even loosen it to get it off
the one that holds the wastegate solenoid on cracked or snapped while tightning it, and the other half is still inside, and the top portion is just loose and dangling there right now. I called the dealer, and they said those bolts were discontinued. The one that holds the solenoid on has what looks like a stud or something under the nut, but the others dont seem to have these.
First what is the simplest way to get the stripped one off?
Second where to go to get all four new ones, so i can ditch the old crappy ones. Auto parts store? which one? the guy at the dealer said if i bring one in he could match it up with the same new one. But do i need those studs on all of them? or do i just get the replacements and screw them right in? I know the solenoid bolt has to have a nut to it due to the fact that is the only way to hold that piece on to the valve cover, and the top drivers side has a nut holder that other thing on (vacumm hoses go to it from regulator or something
) but the other two screw right down without studs or anything.
thanks
jojo
thanks
jojo
