machinegun
- May 25, 2001
JoJo, To do this correct I would start with removing the valve covers. This not hard but is time consuming. YOu will also need brake cleaner, and new gaskets, I recommend the GM gaskets. Once you remove the bolts you can on the drivers side Cover, you can pry up just a little to apply pressure to the stripped bolt. It should come right out. If not it maybe so stripped that it will just come out with the valve cover. On the passenger side after removal of the cover, see if you can easily back out what is left in the hole with a screw driver that is small. If not try a screw extractor. If this does not work then go to the next step. This you will be doing for the drivers side anyway. Go to NAPA and match up a helicoil kit. This will usually include the drill bit you need or it will tell you the dril bit you need. You drill out the hole to the correct size. On the passenger side this will also drill out the old bolt. Using the supplied tap, tap the hole you just drilled. Install the insert. Now look for bolts that closely match the thread pitch and length. Use a couple of washers to adjust as necessary. If done correct it will stock. Place your bolt through a washer through the solenoid through another washer and directly into the valve cover. Tighten appropriatly. The directions are on the helicoil kit and are easy to follow.
