BARRACUDA1968
- May 4, 2011
I'm getting ready to switch over to SD2 but I have a car show to get to this weekend so I didn't want to make any changes just yet.  I've been doing a lot of reading and most of the info I find say's to set the TPS to 42.  Mine was set at 46.  On a whim I decided to mess with it tonight while in the shop.
I loosened the 2 screws on the TPS sensor and adjusted it to 42. Of course the idle moved so I adjusted it. Then the TPS moved etc. I messed with this thing for ever. I even had the throttle screw completely off the throttle plate at one time and the car ran. It never really ran bad no matter what I did.
My problem was when I put it in gear and then back in park it wouldn't idle down. Stayed at 1300 rpm ish. So I kept going with no better results. I about threw in the towel but decided to take one more crack at it. I adjusted the throttle blade to where I figured it was just cracked open and adjusted the TPS to 42. Then I tightened the TPS screws back up and it's perfect now.
I guess I had a vacuum leak because I didn't tighten the TPS back down? If this is correct why didn't I find this info in any thread I researched? Maybe I'm and idiot or this must be common knowledge to everyone but me.
