Selling my 1985 Buick Grand National that has had a ’87 Intercooled swap…it’s no longer a “hot air car”…below are details of the build.
1 of only 2,102 Produced
Engine:
Ported stock heads
New valves and Springs
RJC Headgaskets
Head Studs
PT 70 turbo with a P-Trim Wheel
Ford power Stroke intercooler
LS1 Mass Air Flow Sensor
RJC Power Plate
4" Big Mouth Cold Air Intake
Razor's Alky Injection
Keith Mease 3" down pipe
3" ATR single shot exhaust with cut out (has a new Magnaflow muffler..couldn’t stand the drone)
TA performance headers
Power Logger data logger
LC-1 Wide Band
Turbo Tweak Chip
65lb/hr Injectors
Transmission:
Freshly rebuilt by Jimmy’s (built to handle 800hp)
Vigilante 9" lock up 3000 to 3400 rpm
Rear end:
Eaton Posi
Moser axles
New bearings and gears - stock 3.42 ratio
TA Performance Rear Cover
Chassis/suspension/Body:
6 point roll cage
Metco rear suspension
Bilstein Shocks
Rear Air Bags
Body braces
5 under hood braces
Rear seat braces
Corvette Z06 Front brakes w/ Line lock
SIMMONS 17in wheels
BFG tires with only 600 mile on them
PST suspension bushings in the front end
Front lowering springs
Corbeau seats
Corbeau 5 point harnesses
Fiberglass front and rear bumpers
This car is really fast and has a ton of documentation and a gigantic barrel of alky that goes with it. Has all the desirable bolt on’s and mechanically perfect. The only down side is the paint is not great…not horrible, just not great…has some dings. Had paint done back in 2005 and could stand to be freshened up..it’s the only repaint. Car has ZERO rust and you can eat off the underside…also has never been wrecked. It does have a ’87 grille and new headlight bezels and tinted lens. NOTE: the previous owner removed the heat and AC…my next project on the car was to install a Classic Air system which runs about $1K.
I’ve never raced this car at the track…the previous owner ran a best of 11.41 in the quarter with slicks on a smaller turbo. It’s built to run 10.90’s and can spin the tires at 60mph on street tires. If you’re looking for a stock GN this isn’t the car for you…if you’re looking for a show car then the car will need some new paint…but, it was built to be a street fighter. In the documentation there are time slips showing the improvements as mods were made. Emails of when engine and trans was bought, parts receipts, and research done on the build.
I’m looking to get 15K as is…if later it doesn’t sell for that price I might go less by removing the Simmons wheels and installing cheaper wheels. The Simmons with zero imperfections and brand new tires are going for 3-4K. There was $30K spent on the drive train and suspension alone.
Not desperate to sale…just looking to see if any interest. Car is currently in Arkansas.
I work a lot so best way to communicate is PM or email to rickcarterrac2@aol.com
Engine:
Ported stock heads
RJC Headgaskets
Head Studs
RJC Power Plate
LC-1 Wide Band
Turbo Tweak Chip
65lb/hr Injectors
Transmission:
Rear end:
Eaton Posi
Moser axles
6 point roll cage
Bilstein Shocks
Rear Air Bags
Body braces
5 under hood braces
Rear seat braces
SIMMONS 17in wheels
Corbeau seats
