Hi, finally discovered what has been the problem causing coolant mixing with oil. I had tried already to change head gaskets, intake gaskets, checked heads for cracks, smoothed the heads and intake surfaces but nothing, still got white cocoa in my engine. So I thought that there cant be any other reasons and looked for block cracks and there it was, in the 5th cylinder wall. And it only took about 1,5 months and couple of thousands of dollars to find it
Now, I sleeved the cylinder, will change all the bearings and it should be done.
But before starting the assembly I have some dumb questions as my knowledge about Buick engines bases on my other buick's (GS 455) engine (464 stage 2 headed).
I try to explain as well I can and I hope you understand and can help me.
There's a thing in the timing cover where usually distributor goes, it doesnt seem to be distributor but it looks like it. Is there something specific I should know when I put it back?
If there's any other important facts I should know about re-assembling stage 2 engine then please share.
thanks
Veljo
thanks
Veljo
