some oil smoke
87TIGN
Death by boost
There is some oil smoke that comes out of my valve cover breather on start up and while the car is running. This is a new thing, could it be due to the PCV valve? I got the PCV from someone on the board out of Colorado that is supposed to help with the oil leak I have in the back of the oil pan gasket from the crappy stock PCV valve not doing its job right. I put the PCV on about a year ago. Should I just clean it and see if it helps? Im sure someone else has had this problem right?
-Andrew
