In GM High Tech Mag.
A stock GN took
524' to stop from 100
319' from 80
179' from 60
Vacuum Assist dropped that to
421' 100->0
261' 80->0
150' 60->0
Populat Hot Rodding just did a Baer conversion on 76 Camaro
Stock 60->0 was 217'
Better Tires 60-> 164'
Then after adding A Baer Font end kit, at $1,345, and rears at $875
Managed to stop from 60-> in 134'
Today while playing with my new G-Tech RR. Using my 02 Camaro fronts at $650, and $250 rears, I did
75->0 153'
80->0 175'
Without having optimized the brake balance, and these were just first tries. The 75->0 was with some front wheel lock up.
I should mention that it's plowing time, so the roads were rather dusty. Oh, justa vacumm power booster. Should I mention that having another 1,000 PSI of line pressure would just have locked up the fronts easier?. The 85 Regal Master Cylinder, vaccum booster setup. 225/50x16 fronts, and 285/45x17 rears, all are DKW BF Goodrich.
A stock GN took
319' from 80
179' from 60
421' 100->0
261' 80->0
150' 60->0
75->0 153'
80->0 175'
