ablackFormula
- Mar 16, 2004
Hey guys, I'm hoping I can get some insight as to what to do here, I'm at a complete loss:
I just installed a FAST unit in a 95 Formula (Firebird) with a stock LT1 engine (normally aspirated.) I did some datalogging with the stock computer in place and found that the car idles with an average pulsewidth of 2 milliseconds.
After installing the FAST unit, the car idles with a pulsewidth greater than 5, close to 6, milliseconds (but idles smoothly). The car constantly blows out black smoke and idle, during driving, deceleration, all the time. Idling in a still spot will leave stains on the ground it's so bad. I pulled a plug and it's black as can be.
I tried adjusting the a/f ratio and ve tables, and got the pulsewidth down to 2 seconds, but now the engine hunts horribly and I can't seem to adjust for it in the IAC tables (and the throttle blade screw has already been opened a good amount to get the IAC counts down to around 10 when the pulsewidths were at 5.) RPMs vary from 4 to 500 all the way up to 1000. Pulsewidths go from low 2's to 11's in milliseconds.
Timing at idle is set to 20 degrees. If anyone has any ideas please share, and if you'd like to see some files I have calibration files and a datalog of the engine hunting.
The electrode on the spark plug does look a little worn, but the gap isn't off by more than .003". I'm not ruling out physical problems with the engine, but it just seems odd that something would go wrong from changing nothing but the computer.
