spal-fans
gmpower6
Seen a set up on a sabb today does anybody know will they work on a gn? The sabb was an 85
Thanks Sean
Ok nobody knows? What size are the one's ramchargers sells? I can see if they are close. Thanks Sean
Hola.
Why not measure the space that you have now, and fill it? Just measure the readiator and the space back to the intercooler.
It doesn't have to fit 100% on. You just want to make sure that the rests up against the radiator without rubbing. To close and it will rub, to far and it will suck air from around the sides, instead of through.
