Bowtie Mafia
- Mar 29, 2011
I am having problems with my '87 GN, it started to stumble under initial acceleration and 2 minutes later it died on me and hasn't started since. During cranking the motor backfires. I have recently replaced my cam position sensor and since this problem my crank position sensor. I have tested the spark control module and the values it gives are way off what is specified in Kirban's book. (I can give the values I measured if it helps). Would that spark control module be the cause of all my problems? Or is it something completely different? Thanks.
