Has anyone had unexplainable spark knock with their car at part throttle??
A friend of is having trouble with his TTA, he has checked the DP and nothing is hitting. If you hold the car around 4-5 psi at part throttle it wil continuously show 10-15 degrees of knock but nothing at WOT at 23 PSI and Razor Alky. I am going to attach the DS file so someone can possibly help. The initial problems that I see is the MAF shows only 100 grams at WOT (T+ and extender extreme), the next issue is a O2 sensor dropout and at the same time the knock shows up. Also the LV8 dosen't show steady as I believe it should. Rename the file and take the .doc off and look at it with DS. Any help would be appreciated so the more replies the better.
