Mr. T-Type
always broken
- Jul 23, 2002
I finally fixed every problem with my car except one which I can't seem to put my finger on. Found 4 vaccuum leaks, a bad MAF sensor and a bad TPS.
The car is idling correctly, not hesitating when I gas it, and not losing all power after 10psi.
However, if I go WOT, the car will overboost (I'm supposed to be on stock boost which I'm told is 15psi) past 15psi and then gasp and lose all power. I can hold go about 66-75% throttle and build it up all the way to 15psi (around 4000-4200 rpm). Anything higher than that will cause it to overboost and gasp.
I don't want to throw parts at it and I don't know anyone with coilpacks I can borrow. Can anyone help me diagnose this? I'm throwing my Walbro 307 on tomorrow night in hopes that the stock fuel pump is what is holding me back but I highly doubt that.
Only mods are 36# injectors, 2.5" downpipe, and Duttweiler necks.
