Spark plug cross reference
SS/GN
What Autolite plug is the same as the NGK UR-5.
#23
Copper core, extended tip, resistor, 5/8" hex, 14mm thread with .460" reach, tapered seat.
For a non-extended tip spark plug, Autolite # 144 is the one to go to. Heat range is between # 23 & # 24 plugs, but has a standard length tip. I run these at .040" gap with CnP ignition.
RemoveBeforeFlight
