Spark Plug Recommendations
Jas89TTA
What plugs would be best of my TTA and what gap? I was running Ac-Delco R42LTS gapped at .032 Not sure if this would be the ones to run since my car's not stock. I was wondering if I may need a hotter/colder plug than the stock ones. My set up is T66 bb turbo, 72# inj, alky, TTA champion ported heads and intake, THDP, AFPR at 42psi, 210/210 roller cam, 70mm TB with matching doghouse and running about 22-25 #'s of boost. I had a issue with the #2 cylinder, the exhaust seat came out and not sure if maybe the plugs were the wrong heat range. Thanks, Jason
I run the same R42LTS plugs in all of mine, gapped .030 in my GTA up to 27psi no problems :)
HTH,
Steve
R42LTS ditto.. or the NGK TR5.. or the NGK TR6 a little colder.
